Correct water pump for 1996 115HP Evinrude Intruder
DWilks
I'm trying to order the right water pump for my motor but find that there are
two different ones. Model: E115GLEDR and don't know how to tell if it's a 60
or 90 degree(whatever that means) ...also some list as SL, DL??. Can someone
tell me how to find out what I need to know to get the right water pump...:confused:.Thanks
Willyclay
DWilks
Re: Correct water pump for 1996 115HP Evinrude Intruder
Welcome to the forum. The members here are great and the experts, which I am not, can help you with any problem. The link below should get you to the correct part number for that model. Just make sure you copied the model number correctly because it may make a difference. Good luck!
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1996&hp=115&model=E115GLEDR
thanks, Willy...that is the place and figure that I was looking at to get the info....but it list two separate
numbers for the water pump and I must need more info to choose which one
wilde1j
91 0434421 WATER PUMP REPAIR KIT (Includes impeller hous ng) 1 $66.63 USD
You can find all parts at the BRP Evinrude site and complete parts diagrams as well.
Willyclay
There ya go! Jim is one of those "experts" I mentioned. Good luck!
AlTn
looks like 0434421 supersedes to 5001594...$53.73 for the 20" shaft..or, 5001595..$60.32 for the 25" shaft at marineengine.com
DWilks
AITn, thanks but how did you find out that the 5001595 is for a 25 inch shaft vs a 5001594 for a 20 inch shaft? I know
by the model number(I did buy the manual from iBoats two weeks ago) that I have a 20 inch shaft. Would you answer
that ...please
wilde1j
The model number nails the shaft length. Just decode it.
DWilks
wilde1j, I did decode it...that's why I said I have a 20 inch shaft..but would still like to know how to get
the correct number for my particular model. The site, marineengine.com list two different part numbers
for a 115HP. "115HP 1979-Up" list part number 18-3392, and then list "115HP SL,DL 1995 & UP" list part
number as 18-3315-2. That is why I was asking "what does SL, DL mean" so that I could get the right
part number...Thanks
AlTn
marineengine.com..your year and model no....gearcase..for the 20" model part 91..for the 25 "model part 97
DWilks
Thanks AITn, I will go with what every one is saying. If the sites were listing for a 25 inch shaft, I would think they would use the
model number of E115GXEDR(using an X instead of an L) for the 25 inch shaft...at least going by the manual. Thanks all for the info
and I consider this to be the end of this thread :)
