Corroded Starter Relay Wire?
Charlie O.
I'm replacing the starter on a Volvo Penta 5.0 and am installing new connectors. When I stripped back the starter relay wire (yellow with red stripe), the wires look blackened (see photo) Is this normal for this wire? Is this oil intrusion? I stripped back more and found the same. Any recommendations?
muc
"Retired" Association of Marine Technicians...
Not normal.
Water intrusion.
The recommend repair is to keep going back up the wire until you get past the corrosion. A short term repair is to just clean it up with a brush.
