Corrosion at O-ring between outdrive and transom
cliffblue
While my alpha outdrive was off for service, I noticed corrosion in the o-ring recess of the transom mounted part of the outdrive. The funnel going in was corroded also. The boat is fresh water only. Cleaning and painting is the only fix I can think of, but I don't know the best way or primer or paint. Any suggestions? Thanks, Cliff
Bt Doctur
Re: Corrosion at O-ring between outdrive and transom
nothing to worry about.
