after removing my engine anodes I found I probably should had done it sooner. can I spray corrosion block or another salt/corosion product directly into the cooling system? I use salt away regularly. could this be the culprit to my earlier querry?
wont help<br /> even saltaway is marginal. the anodes have nothing to do with cooling unless they break apart and block a passge. its somewhat common on the 3.1L motors but not the rest. the 3.1L motors use pencil anodes. what problems are you having. my memory is old
