corrosion on trim ram assembly? reducing
pancake
what the best way to hopefully slow down/reduce the corrosion and pitting that is occurring on the of the aluminum part of the trim ram assembly. it sits in salt water. anodes are all in good shape and there is nobody docked nearby. its not leaking but if i don't do something it will.
thx
robert graham
Re: corrosion on trim ram assembly? reducing
I always spray my entire tilt/trim assembly including motor, pump, rams, with white spray lithium grease. Once it sets up on there it protects very well and you can re-apply every now and then. My motor is a 1999 and the tilt/trim is like new, under the grease coating.
pancake
what brand have you been using?
robert graham
Yamaha makes a Spray On Protective Coating, but like most of their stuff, it ain't cheap, so I just get the spray grease at Autozone or Advance Auto and it's much cheaper and works real well. Any brand of spray on lithium grease should work fine. Clean all the rust, corrosion and deposits off as much as possible before you spray it. Good Luck!
robert graham
Also, be careful not to spray grease on your zinc anodes on the lower part of your motor bracket.
rodbolt
any idea of the brand of motor or the horsepower?
janmart
Sorry can,t advise.Has anyone had a case of No assembly screw point for the Continuity Strap on 2007 manufactured 225 HP motors.Have just forked out $3000 to replace POWER TRIM RAM that had no strap.Mechanics(indipendent) claim ccorrosion due to this.Suuzuki won,tanswer!
RRitt
thx
add a slab of zinc as close as possible to the problem area. make sure to contact bare metal. zinc on top of paint and/or painted zinc does nothing. figure out which piece of stainless is the culprit and - if possible - paint the SS it to reduce its galvanic activity.
pancake
thx, i removed and cleaned the zinc in the very bottom. then applied a good coating of lithium spray grease and will keep an eye on it . the lower part of the trim ram assembly sits in salt water all the time unlike newer boats which are mostly out of the water.
its a 20 ft 84 wellcraft center console fisherman with a 2001 yamaha 150 2 stroke hpdi z150tlrz.
