corrosion pitting on gasket surface?
Teutonics
A follow up question to my paint question...<br /><br />There is some corrosion pitting on the gasket surface of the gear housing for the impeller housing gasket. I want to prep this and paint it properly, and per the mercstuff.com site, I need to sand/remove the material down to the bottom of the pit. However if I do this, the gasket will not seal properly. Is there some product that I can fill the depressions with (like bondo?), or what other options do I have?<br /><br />Thanks!
Re: corrosion pitting on gasket surface?
It Sounds like you're Over Due for a New Housing...........<br /><br />That surface requires a Machined Surface,.........Not Dremeled........<br />I Really Doubt you'll Ever stop That Leak........ :(
tommays
<br /><br />How bought a photo of what your talking about is any worse than this ?<br /><br /><br />tommays
boathog
gasket sealer will fill in all the gaps
Teutonics
What type of gasket sealer would be recommended? Quicksilver Perfect Seal?<br /><br />Here are the pics, sorry for the size. I couldn't shrink them down enough and still be able to see the defects. The worst spot (by far!) is in the upper right corner, and this is not a spot that needs to be sealed. The second pic is a close-up of that spot for reference. The other spots can probably even be filled with paint.<br /><br />
<br />
tommays
IT looks fine just to me just some light cleaning and paint DONT sand out ALL the pits :) <br /><br />tommays
Trent
Loctite 515 will work fine. Most autoparts stores can get it. Fills gaps up to .050<br /><br /> 515<br />Or 518 will work well also.<br /><br /> 518
rdh2059
You could use a good metal based epoxy. Clean really well, apply epoxy, then sand smooth. Those corrosion areas don't look too deep, so you should be able to get away with a strong filler and sanding smooth. <br /><br />Rick
I like the Lock-Tite Idea,...... That really ain't that Bad......
