corrosion protection on SS bolts in aluminum housing
jgresham75
Have some corrosion on SS bolts in aluminum outdrive. Not a major problem but does anyone have any suggestion to keep corrosion to a minimum? Anode are working fine. How about marine grease?
Thanks
sschefer
Re: corrosion protection on SS bolts in aluminum housing
Merc recommneds using 2-4-C Teflon lubricant. It's what I use and it works fine. You can usually get it at West Marine or any decent Marina.
cr2k
You can also use Gasket Sealing Compound or Aviation Permatex.
Brentathon
I'm curious exactly which bolts (and drive) are you talking about?
Any SS bolt that has good conductivity with an anode-protected drive shouldn't be corroding. My boat has spent 6 months/year out of the past 20 years in saltwater, and the ss bolts are perfect........the regular steel swivel shaft is another story, though.
dubs283
true the bolt won't corrode, but if installed into aluminum, there is a chance of siezing due to the contact of dissimilar metals
anode hardware is sold with a blue coating on the threads to ease the removal when replacing anodes, i have never had an issue removing them
if you must coat a SS bolt with anything, i would use perfect seal gasket sealer
Outsider
The best preventive is to remove the bolt annually, chase the female threads, reinstall with a light grease coating ...
ChampionShip
Wouldn't permatex anti-seize compound be the option for this?
