Re: cost to restore compression?
Hi SD,<br /> Assuming your compression gauge is up to par, your compression readings are way below where they should be. As low as they are, I doubt decarboning will bring them back up to spec. Being that your other posts seem to show loagie performance, I am betting it is time for, at minimum, a re-ringing. That would also entail a good honing, new seals, gaskets, etc.<br /> At worst, you're in for a complete rebuild with boring, new pistons, etc. If you do the basic labor yourself and plan on keeping the motor, then it could be worth it. If it's something you're planning on unloading in the near future, dou'd never get your money back out of it... Just a few things to consider...<br />- Scott
