coughing 6hp evinrude
abalone
keeps coughing at low speeds have replaced reed plates top seal another carby still persistant coughing no differance when adjusting low speed jet
OBJ
Re: coughing 6hp evinrude
Hello abalone, welcome aboard iboats....<br /><br />Tell ya' what you might try, with the engine running, idle will do, dribble some carb cleaner along the seams where the crankcase is bolted together and any place where there are seams.<br /><br />Nuther trick....put a piece of clear tubing between the fuel pump and carb. Start the engine and watch the flow of fuel through the tube. What your looking for is air bubbles. If you see any, your sucking air someplace.<br /><br />Could you post a year or model number? This would help know what you have.<br /><br />Thanks.
abalone
Originally posted by abalone:<br />keeps coughing at low speeds have replaced reed plates top seal another carby still persistant coughing no differance when adjusting low speed jet
abalone
1970 or 72
