Could anyone recommend a size and pitch prop for a 70hp OMC on an old 24' pontoon?
jbjennings
1974 OMC 70hp outboard mounted on a standard Aloha pontoon boat (not a tritoon) with standard seats and 3/4" marine plywood decking on floor which is also probably standard.
I was hoping someone could recommend a prop for this setup.
I sure would appreciate it,
JBJennings
SkiDad
Re: Could anyone recommend a size and pitch prop for a 70hp OMC on an old 24' pontoon
edit: i have bad advice so I'm just taking it out
jestor68
The Evinrude site has a couple of tests of their 75 on 22 ft pontoon boats and both a using a 11 pitch prop to turn 5400-5500 rpm.
Bear in mind that these engines tested are brand new.
It seems reasonable that your 70 might do OK with a 10 pitch prop, bearing in mind that the rpm can go as high as 6000 rpm on your 70.
steelespike
jestor generally has these things nailed down pretty well.
I would only add that the 70 uses a 2.42 ratio while the 75 uses a 2.00.
Makes me think that assuming the 70 is sound an 11" would be closer to what you need.
Jestor, does that seem reasonable?
jestor68
With so many unknowns, the 10-11 pitch range seems reasonable. :)
Bob_VT
What prop is on it right now? Is there a tach connected? Do you know the rpms that it was turning?
There are also 4 blade 13" props but, that will all depend on your present situation.
dazk14
Ensign
Without ANY speed data.
Michigan wheel make a 10" pitch 4 blade that would be in the hunt. I wouldn't go smaller and I'm not aware of an 11" or 12" 4 blade.
Rkrough
The 11 pitch on a 70hp should be about right for a 24' pleasure 'toon. We had a 1985 70hp on a 22' pontoon workboat last year that we used to transport lumber on. We had an OMC 14 x 9 pitch on and it was perfect for maneuvering and towing, It would still make ~15 knots at 5500. We also installed a CDI power pack(113-2556) with a built-in 5800 rpm rev limiter to prevent over revving when the boat was unladen.
