Help! i am pretty frustrated right now. I have an older '79 omc sterndrive i/o with a gm 350 small block engine in it and this season I have had intermittent trouble with the engine suddenly cutting out at higher rpms. At first I was convinced it was the carb not functioning properly so I replaced it (not cheap!), then it started doing it again, and so I decided after checking what was going on while it was underway and viewing the fuel input into the carb that perhaps it was the fuel pump, so I replaced it. I have also replaced the points, plugs, condenser, and plug wires, and coil, and am still having intermittent trouble with this problem. I was pretty convinced that it must be a vapor lock, and so after replacing the fuel line and insulating it to insure it wasn't touching the coolant hoses in any manner and making some small adjustments to the carb linkage going to the secondary it started running great again today. Then whenever i tried to bring it out of gear and put it into neutral, it got stuck and I was unable to shift into neutral or reverse. So I checked back at the cables and pushed them around a little and had my friend try to shift into neutral and then it went into neutral and I could shift into reverse and forward again, however the engine sounded like it was missing out at times and almost like it was going to die. So my friend got out to get the trailer and I decided to see if it was still running great while waiting for him so when I gave it full throttle - it cut out and lost almost all power again just as it has been doing intermittedly all season thus far,however now I had no problem with it sticking in gear. I must mention however,that when it does lose power and I have to pull the throttle back to get it to start running well again, that the engine never completely dies, but rather kind of "diesels" like a car that won't shut off when the key is turned off does sometimes, until I pukll the throttle back and then it regains all it's power (at the reduced throttle and rpm's). I am very frustrated because it does not do this EVERY time, in fact as I stated earlier it was running GREAT at full throttle for a good 10 -15 minutes before we reached the boat ramp and I found it was stuck in forward. Could the shift assist module be the culprit here? Since I have replaced almost every other thing I can think of, I am beginning to believe it MUST be what's wrong. And also My shift assist module bears the number 982-749 T9 8 cyl. and in the iboats catalog for engine parts doesn't have a listing for that exact replacement part. Any one know if the replacement parts listed would be compatible with the part number I mentioned?
