1996 Maxum 1900SR.
4.3 liter Mercruiser 2bbl with Vortec heads.
----Here's the crux, up front: Could a blocked line from the water pump to the exhaust riser result in water in the crank case?----
Dewinterized her last month, ran her for about 5 minutes (ran great) then found water in the crank case. It was full.
I'm confident that I have a blown head gasket or block, but I have a nagging doubt I want to eliminate before I pull the motor for disassembly...
When I winterized her last year, one of the plastic threaded plugs that drains the exhaust risers at the L-shaped fitting that runs to the water pump broke off. I fished the piece out and reminded myself to order a new one before summer...Then forgot.
Fast forward to last month when I remembered the plug. I went to the hardware store for a temporary (or permanent) solution so I could run the boat, and ended up buying the shortest stainless steel bolt I could find with matching threads. It was about twice as long as the old blue plastic plug. I put her in and kept dewinterizing.
Here's my nagging question. If my SS bolt is long enough to block the passage of water from the water pump to the exhaust riser, could that be the cause of the water in my crank case? Posting a link to an image of a similar riser and fitting.
