Re: Could one of the wiring gurus look over this wiring diagram?
It appears to be ok except for the NAV/ANCHOR lights. That switch normally needs to be either a three or six terminal ON-OFF-ON switch. You cannot make Nav lights function correctly with a single switch. You can certainly make both turn on but in operation both must be on while under way. Only the anchor/all around light must be on when not under power. A three terminal switch needs a diode added while a six terminal switch does not. Search this forum -- pictures and diagrams for the wiring have been posted many times.
