I am trying to investigate a problem with an electrical choke. The choke has a + terminal and a - terminal and the voltage should heat an element which causes a bimetalic coil to change shape. <br /><br />If I put a continuity tester on the + and the - it shows no continuity. If I check for resistance it measures 8.27K ohms. <br /><br />The voltage that is designed to go through the device is 7.5 volts. Therefore 7.5/8270 should give me the current draw in amps e.g 0.000906892amps<br /><br />My thinking is that this will not get anything hot and the resistance is too great so it must be broken. Is my thinking correct in general electric terms or am I missing something?<br /><br />Regards<br /><br />Chris
