Couple drops of fuel leak out of carb...
ScAndal
When I start the boat about a drop of fuel leaks from the carb where the fuel line connects. I think it's due to a partially cross-threaded carb socket from connecting the fuel line. I've monitored it and it only happens when started and it only leaks 1-1.5 drops. <br /><br />Is there anything I can do about this without changing the carb? <br /><br />ScAndal
lilmandavis
Re: Couple drops of fuel leak out of carb...
get a new fitting and stainless pipe . leaky fuel and boat go "BOOM"
ScAndal
lilmandavis,<br /><br />I believe it's actually the socket on the carb that is cross-threaded. The socket is molded onto the carb and the entire carb would need to be replaced.<br /><br />ScAndal
lilmandavis
yuck. thats yer call there buddy! i just know that a fire on the water is pretty serious. and with gas engines.... theres lots of things that could happen to burn that "little" bit of fuel. a few hundy is deffinately cheaper than a fire. if its a holly just buy that piece of the carb. you wouldnt need to replace the whole carb. and ummm dont cross thread fittings. its just not good for them lol!
bruceb58
I wouldn't use that boat until you got that fixed...and if you do...buy a lot of life insurance before you go.
ScAndal
Is there any type of substance that I could use on the connection to seal it?<br /><br />ScAndal
lilmandavis
theres lots of cheap gobble fixers that might work but your goin to have to do it again sooner or later. fix it right. fix it once
calwldlif
If you can screw and unscrew<br />the fitting there is an epoxy<br />used in carbs to seal plugs in <br />holes made during manuf and for cleaning.
ScAndal
lilmandavis,<br />I really wish I could repair it but I can't afford it. It's either find another fix or don't go boating this summer.<br /><br />I'm thinking of trying http://jbweld.net/products/marine.php <br /><br />ScAndal
whywhyzed
Banned
Take the carb off, and take it to a machine shop - have them clean the thread up .. probably cost you less than the JB
lilmandavis
no matter what you do ...repair the threads. dont try to stick some glue and call it good. try to retap the threads and clean up the fitting. put some pipe tape on there after. but dont get sloppy as the tape will get into the jets if allowed to. carefull when backing out. dont want to crack it. i like hystats idea if you dont have the tap.
michael-lagrange
Scandal:<br />What everyone is telling you is Saftey first on the water, do what ever you have to to fix this problem rite.<br />getting a machine shop involved would be a good Idea.
