I am interested in checking my timing; however, I do not know the correct procedure because I am not sure which Thunderbolt ignition I have. The motor is a 1997 4.3LX Gen+ (s/n 0K012346). Can anyone advise which Thunderbolt ignition system I have.
I took a couple of pics of the distributor and have a few questions. What is the white plug (with nothing attached) on the side of the distributor.
I also do not know what the black color wire is that is not attached in the following pic. Can not trace the source since it just appears coming out of a wiring harness behind the engine. I'm thinking maybe a ground but not sure what to.
I included an overall pic of the engine. I have two plastic corrugated wire covers that are being used to funnel fumes from the valve covers back to the flame arrestor. Is it possible to remove these and just plug the covers? It just seems like a very "rigged" system.
Please ignore the black/red wires on the lower left side of the above pic. Those are the wires for the disconnected (for the pics) engine hour meter in the intake cover. Thanks for any help and/or insights.
