jtexas
- Oct 13, 2003
- 8,646
little bit of water in gearcase, new drain & vent plug washers didn't help.
If I'm reading this manual correctly, seal replacement doesn't require removal of propshaft or driveshaft - but the bearing housings have to come out - does that sound about right? Or do you always completely disassemble & inspect in cases like this......it's not making metal, and who can afford all those "special tools" - must be 3 dozen!
When the L/U came off I noticed the driveshaft grommet (top of water pump) was displaced, about half-way up the shaft......doesn't appear that would cause any problems....right? or did I miss something last impeller change?
also, any tips on freeing a stuck prop thrust washer?
thanks!
almost forgot...1979 3-cyl (mech shift)
thanks!
