enginesilo
- Jun 9, 2008
- 355
I pulled my Alpha 1 Gen 2 outdrive off for the first time. Plan to leave it off all winter while I work on the outdrive indoors. What do you recommend I do with the stern drive opening now that the outdrive has been removed? Should I cover it with plastic, or cut a piece of wood or plexiglass and screw it on to cover up the hole? I don't want to risk rusting my gimbal bearing or anything like that inside of there.
Also, do I need to oil the engine spline shaft or anything like that so it doesn't rust? Not sure if would rust, but its typically not exposed when installed so I figured I'd ask if I should rub it down with a little oil or something.
