Cowl Frame Ground vs. Engine Ground?
OldCoyote
Installing a wiring harness on a 76 merc 115 and the instructions refer to engine ground and cowl frame ground. What’s the difference and how would I do each?
Faztbullet
Engine block is considered engine ground and lower and upper cowl and brackets are cowl grounds. They the grounding straps from brackets to cowls to engine block
