OK, I had really good luck adjusting the carburator and figured out the mystery screw on the tower is for idle speed and in gear speed.
However, I found out last night when I put the cowl cover on, it starts sputtering and dies which I think is lack of air.
My question is, are there any air vents on the cowl or are there some on the motor that I need to check? I suspect whatever air passages are there got clogged. It doesn't immediately die, takes about 30 seconds or so to run out of it...
