cowling insulation
procraftmark
I have an 89 force 50 .i think the oil and gas took a toll on the open cell foam that was in there it disintergrated to dust. Can i use neoprene, or would something else be better.
thnx
mark
D
DJ
Guest
Re: cowling insulation
pcm,
There are insulation kits available-aftermarket.
Check out West Marine. www.westmarine.com
I always recommend iboats mega mall, but they don't carry it-I checked.
D
DJ
Guest
Hmmm.
Under cowl insulation is pretty basic. Usually it is just 1/2" foam, glued on.
You can use anything similar. The aftermarket kits I used to see were 1/2" foam with a foil outer cover.
Chris1956
There is a form of insulation which looks like bubble wrap, but made of mylar. That may work well and is waterproof.
