I noticed some cracks located at the bottom rear portion of my rear livewell. The cracks appear to be similar to jel-coat cracks you see on many fiberglass boats. But after further inspection (in certain spots) the cracks actually extended through the fiberglass and is visible on the back side of the well. I have repaired the fiberglass on areas that I can reach anyway (on the outside), but I'm still getting some small leaks that are present where I couldn't do the patch work (can't reach it on the outside underneath)...<br /><br />Anyway, my question is, has anyone attempted to patch the inside of a livewell. It's obviously coated with a white gelcoat material. Can I get away with some good sealer, or is this a sand, sand, sand, and fiberglass patch job?
