Re: crack repair
First you'll need to identify the severity of the necessary repair. If it's leaking, it indeed sounds like it's cracked through. <br /><br />At the minimum you'll have to feather back from the crack, and build out cloth and resin in layers. I'd suggest epoxy resin for the repair, more expensive, but a bit more forgiving for the newbie and much stronger. <br /><br />At the least if you've never done it before, I'd suggest A book called "The Fiberglass Boat Repair Manual" written by Alan Vaitses. You can search here on iboats for it, or I know Amazon.com sells it. Great manual for the unitiated. <br /><br />Without seeing it it's hard to tell how bad it is, but most any fiberglass can be successfuly repaired. Feel free to ask questions here though, there are a lot of great minds... I know I can attribute a lot of my success to help I've received here..<br /><br />-Roger
