Cracked block question
mercurymang
Master Chief Petty Officer
OK, I got the power head off of the 850 last week and have spent the last several days cleaning everything. Last night, I decided to turn the power head on the side and take a look under neath. Here's what I found.
The crack doesn't appear to go very far. So is it scrap, can i get it welded. Can i run with it as it is?
bajaunderground
Re: Cracked block question
I would recommend cleaning it up and taking it to a machine shop and get their opinion on a fix/or replace. Aluminum can be repaired properly with a TIG welder? I would advise against a MIG welder?! I'd suspect either and overheating situation or a stress crack from use?
Bob_VT
Dealer's choice ;) that is an exhaust to the mid section....... no fuel intake, no compression and basically it will not hurt anything. I guess you could have it welded for piece of mind however...... take it to someone who knows how to weld aluminum cast metal and not just a person who does aluminum "once or twice a year"
I would have it cleaned, prepped and DC TIGed
wired247
Why all the hate for MIG welding aluminum. Ive got a Miller 212 with a Miller spool gun that makes absolutely beautiful full penetration aluminum welds. Kerf that out, weld it and dress and it would never crack again.
mercurymang
Thanks for the response guys. I'll call around and see what they charge to fix it. If its too much, i'll just run it till it blows up.:D
my guy would charge $35
mercurymang
I called my machine shop and they said they would probably be able to weld it for $40.
Faztbullet
I got a block when you get done... when you weld aluminum it draws and thats right about on divider plate, to hot and it warps and plate wont seal then block is scrap. Leave it be as it wont hurt anything and its ran like that for years with no problems...let sleeping dogs lay..
bajaunderground
Faztbullet knows his Mercury/Mariner's I would trust his judgement...if says it's fine, it's probably a little better than that!
Oh, I don't hat on MIG welding at all! For aluminum in tighter tolerance places and sensitive places the heat is easier to control/regulate with a TIG is all.
wired247
You'd be surprised how well a good spool gun with a powerful enough DC power source can weld. Especially on cast where you dont really want to heat the whole thing . I just finished welding a Bobs nose cone on my lower . Did a full perimeter weld and built up a skeg torque tab out of weld metal and it never got hot enough where I couldnt put my hand on it right after welding.
