Last night I discovered my very first cracked block. I have a 1982 Johnson V4 90hp. The crack is on the lower right cylinder through the water jacket to the bottom exterior of the block at about 5 o'clock relative to the center of the piston. This means that the crack is in a hard to access location for anything linear (drill, etc). The crack extends from the gasket surface back into the block about 7/8-1 inch and is 1-1.5 mm across at the face. The cylinder itself is in fine condition without loss of compression.
I've been reading around on the forums that people use a variety of products to fix cracks from Marine-Tex, JB Weld, primer and hardener recently, all the way to taking the block to a welder.
My question is, what would you recommend I do to fix this crack that would be long lasting, not make the situation worse and cost effective (I'm a graduate student on a budget).
I've used Marine-Tex before to repair screw holes in the fiberglass...that required me drilling a larger hole to prepare the surface. Am I going to need to drill the block to make the crack larger before I make the repair? Do you think I will be removing the block from the engine to make this repair?
Thanks for any advice!
