Re: cracked block
You can use the block, you just need to transfer all the parts over from the old engine. Distributor, intake, carb, alternator, pwr steering pump, waterpump, starter, etc. (did i miss anything guys?) Basically every bolt on item. The cam will probably have to be switched because i doubt that buick engine has a heavy duty rv/truck cam. You need marine freeze plugs too. I've heard some people say you need to switch the crankshafts, but i'm not sure about that. I don't think it would be that big of a deal, but maybe another forum member has some more input on that. While you're at it, put a new coat of marine engine paint on everthing.
