Re: cracked block
They have this nice new nickel rod that allows you to weld cast iron with ease these days, the question is; is that crack you see the only damage? You will have to remove it to weld it, but it will be cheap if you can tell it is a single crack and accessable. <br /><br />My friend went and found a 400 block, and good choice of cam, heads, and intake and ran his 305ci from 47+ to 74 mph. OK, the cam was really big on this one, but it worked. I only know of having to use the exhaust, cooling system, ignition, and your supposed to use the carb; everything else can be automotive, just stay with a marine cam to make things work in the end. And make sure you have no fuel leaks and your ventilation is good back there. Nice time to upgrade!
