cracked ignition coil 1972 100 hp johnson
tiger 650
The motor has no spark, the plastic coil is cracked very slightly.can I check it with an ohmeter?
Hooty
Re: cracked ignition coil 1972 100 hp johnson
Sure ya can. Check both primary and secondary windings. I don't know how much resistance there should be but it'll be in the manual. <br /><br />c/6<br /><br />Hooty
The Marine Doctor
If the coil tests ok...maybe put some black neoprene over the crack to help seal it up.<br /><br />TMD
