Cracked trailer fender
khe
The curbside fender on my boat trailer has a stress crack. The only thing I can think would have caused this issue is a tire that is out of balance causing vibration that eventually caused the fender to crack. Typically trailer tires aren't balanced but I think I may have all four trailer tires balanced even though I don't feel any vibration when I tow the trailer.
I am going to put my boat in a slip, drill a hole at the end of the crack, then weld it up, grind, fill and paint to match.
Any other ideas on what the cause may be?
looks like the fender has been repaired and repainted once.
airshot
Metal/ plastic ?? Have saw fenders that are not well attached and will vibrate rapidly going down the road, that rapid vibration can cause material fatigue and cracking. Just a thought.....
khe
Metal fender. Welded to the trailer frame. The only thing I can come up with is the tires are causing vibration since they are not balanced and the vibration is causing the metal to fatigue and crack.
airshot
Balancing the trailer tires are easy, most any tire shop will do it. If they were that bad, I would think you would feel it going down the road.
khe
I agree - if the tires were that bad, it would be obvious but I just don't know what else it would be.
