Here is the story:<br />Marine mechanic was docking my boat into a slip and clipped the transom on the dock. The impacked caused the starboard side of transome to crack about 7 inch long crack. <br />It is above water line and is not all the way through transom. <br />I am concerned with the fact that it may start cracking further. My question is: what is the proper way of repairing this? Should the hole be drilled at both ends of crack?<br />My transom is a 3/4" thick and as per visual estimate the crack is 1/4" deep. <br />I showed it to the owner of the marina. He assured me that they will fill in the crack with something called "formula 27". <br />I want to make sure that I do it the right way. <br />Greately appreciate your comments.<br />Regards,<br />Lenny
