Purchased a 1985 Sylvan with a 90 horse Evinrude late last fall.<br /><br />4 cyl VRO Power tilt trim. I took it for one checkout cruise and stored it. It was cold as -10 in storage. Got it out last week and found a water leak. Turns out I had stored it on the trailer with a transom-saver and the motor was tilted up. I think this caused the crack I found in the water jacket under the lower port cylinder. The head is not warped (did not run it long). The head gasket was OK. The crack is about 1 inch long with a 1/32 " gap. Any chance JB Weld or something similar will hold as a repair?<br /><br />If not, my guess is a new short-block, Yes?<br /><br />Any other thoughts?<br /><br />TIA
