Crank, no spark. Need advice.
yamjer
Hello all. Haven't been on for advice in awhile. I'm riding a 1987 Doral Citation, 350. My issue is no spark. I road for 45 minutes to camp last week. Ran fine. Stopped and visited for about 6 hours and went to leave and wouldnt start. Went through check list of ignition troubleshooting. Can say I found ground at tach bared. Unplugged harness. Did this cause my issue? No spark from coil using a spark plug as gap tester. Does that mean Thunderbolt IV amplifier is toast? If so can someone let me know what distributor system to purchase to replace the Thunderbolt IV system
NHGuy
If you still have the tach disconnected it's probably causing the no go. Hook it up (after insulating the bare part), and give er a try.
yamjer
When I say bared wire it was bare from tach to harness connection! So the checklist for troubleshooting says to disconnect the tach wire from the coil. Wouldnt disconnecting the harness be the same? Did both.
nola mike
yamjer
Thanks for the response. I followed flow chart a couple days ago and still had no spark. I saw a post earlier about changing from Thunderbolt to a different distributor system.
nola mike
So the last step in that chart is to have a working ignition, you must not have followed it correctly. Putting in a new ignition will be more trouble than fixing the old.
yamjer
Thanks again. So chart says if no spark change Thunderbolt IV ignition, but have read (Don) says change distributor and rewire and never deal with Thunderbolt again. Didnt sound difficult when I read that. What would you do? I am going to rewire tach (change grounded wire that was burnt) and try the chart again.
achris
More fish than mountain goat
Deadman switch got tripped accidently? Do you have 12v on the coil+? (It's a purple wire.)
Chris.
nola mike
Follow the chart, let us know where it breaks down. It's not a complicated system, an ignition module failure is really the only thing that *might* make it worthwhile to change systems. Relatively rare, easily found on eBay.
yamjer
Follow the chart, let us know where it breaks down. It's not a complicated system, an ignition module failure is really the only thing that *might* make it worthwhile to change systems. Relatively rare, easily found on eBI get 12 volts at the coil. No spark coming out. Used a spark plug as my gap tester and no spark.
Chris.
Yes Chris. 12 volts at coil.
yamjer
Seems to break down at coil. 12 volts there. When doing the spark gap test, using a spark plug, no spark.
achris
Are you putting the spark plug into the end of the HT lead that was on the centre post of the distributor cap? Or into a spark plug leads that runs from the cap?
Chris...
yamjer
Chris...
On center post of distributor cap from coil.
poconojoe
Chris.
This is what I was thinking.
If the deadman switch is tripped, the engine will still crank, but won't start.
