Crank shaft oil leak
cuenta
Guy's if the crankshaft seal leak oil
Can damage the motor or only drooling making a mess..
I notice dirty oil come from propeller after flushing .
99yam40
depends on what motor
4 stroke leaking oil might mean it runs out of oil.
2 stroke means you have oil being added all of the time
cuenta
Sorry for not mentioning it.
Is a yamaha 115 2 stroke
Premix.
robert graham
Maybe you're referring to the propeller shaft where the exhaust from the 2 stroke motor causes some dark colored oil in the propeller?....probably no problem...
99yam40
Most of the time it is unburned fuel and oil that drips out after running, with lots of old carbon with it.
means the cylinders are not burning all of the fuel or the lower seal is leaking.
but there should not be much puddled oil/fuel sitting on that seal anyway.
might check the re circulation check valves to make sure they are functioning properly.
they are suppose to pull that up and get it out of the crankcase
cuenta
Can you explain me how check this valve .
99yam40
Your motor is different than my C40TLRX as far as check valves go.
Mine were pressed into the side of crankcase with tubing attached along the outside
I did not see the same ones I have on the 115 . Maybe I was looking at the wrong parts diagram
on mine I used a syringe and small tubing to see if they would allow flow in only one direction.
found 3 of the 4 bad on mine.
Would not check in either direction.
replaces all 4 while I had it apart
99yam40
look on line for Rodbolt17., and ask him maybe.
he posts on a different forum now a days
cuenta
Thank I take a couple the pic . To show the forum how look the oil in the propeller
cuenta
No Title
