Re: Crank shaft pulley for an AQ271
I'm thinking it is a pretty specific piece, but I have never compared it to any automotive 350 version.
I just had mine off to sand and paint. I am not familiar with the Automotive 350's regarding that pulley, but the one on my engine (The 570 is identical to AQ271C there) looks to be specifically engineered for the Volvo Penta AQ271C marine application.
Look at all the holes, they all have to be there. Notice the center hub has a raised part around the center hole on the back side (crank side) to locate/center it onto the balancer. Also notice on the front side of that hub the raised parts on 2 of the larger holes. Those are to locate the water pump housing to the pulley hub from the front side. Then there are the 3 odd spaced bolt holes for the water pump housing attaching bolts. There can also only be 2 pulleys or the water pump will not be able to mount correctly thru that hub to the balancer.
