Crank shaft removal
Mbalafas
trying to pull the crank shaft out of an aq125a, but I've run into a problem. I have no idea how to pull gear/pulley that the timing belt sets on. The metal cover that surrounds it wont allow for a gear puller. Any help would be greatly appreciated.
Use the B23 volvo engine manual
Use a puller
If you can't get it, take the crank and front cover to your machine shop
