bellboy120
- Oct 8, 2005
- 23
Hello,<br />I am working on an OMC, 153 cubic inch, 120 hp, 4 cylinder motor, currently in the process of installing a new camshaft. Ive got the camshaft in and ready to put the crankcase front cover/oil pan back on. I bought two gasket kits. I noticed that I got donut looking seal that appears to fit into the oil pan where the pulley goes. So, I started to remove the old seal and was only able to remove the rubber piece and the wire band. It appears that the old seal is apart of the oil pan because the metal housing seems to be from the oil pan. I took a screw driver and hammer and tried to pop the metal donut out of their, but it just bent and messed the oil pan. Was I not suppose to remove this seal?
