Re: Crankcase Gasket Replacement
Yes. Thank you. I'm on it.
To my untrained brain, it looks like a "belt and suspenders" kind of thing on the '87. As you probalby know, the crank, case, bearings are all the same. And, the vertical position of the crank in the case MUST be the same. It appears to me that a second seal was added to the '87 (and nothing else). I do have both crankcase heads, so, if the '87 is deeper to accept two seals, OK. If I stick with one seal, I'll use the '79 head.
I think I'm OK.
TY
