CRANKCASE SEAL 1994 120 FORCE
RB45
had a fuel/oil leak inside of cowl- spraying all over, thought it was fuel re-circ line.....someone told me to look at possibly a crank case seal bad...anyone had similar problems, if so can this damage rest of motor??
roscoe
Re: CRANKCASE SEAL 1994 120 FORCE
I think if it was the crankcase seal, that the engine would lose compression and not run.<br /><br />I would clean it up the best you can. Then start it with the cover off, and try to see where its coming from.<br /><br />Might be a good idea to wear safety goggles and have a fire extinguisher handy.<br /><br /> And a friend with a camera to take pictures. Just kidding :)
