crankcase ventilation
flashback
got a 350 chevy that does not have the 2 rubber hoses that connect from the valve coveres to the flame arrestor on the carb.. I do have vented oil caps on both valve covers. is this a problem?
airman
Re: crankcase ventilation
Sounds a little messy to me. Lots of oil and goop in the breather air. If it soaks any nearby foam you might end up with a fire hazard.
rodbolt
hello<br /> it will cause a problem if someone inspects it. other than that it will make a mess. like airman said that oily goo may be a fire hazard. I would put it back together like the factory had it.<br /> good luck and keep posting
