Cranking problems, 1998 volvo penta 5.0 gl
rocky t
engine crank's real hard like the timing is off, i've had the timing checked twice, pulled the plug's to check for water in cylinder's, they are fine, and i have a new battery. any idea,s what to check next? it doesn,t crank hard every time that i start it. thank's
jackd1023
Re: Cranking problems, 1998 volvo penta 5.0 gl
I would clean and check ALL connections, Ground and positive. I would also pull starter and bring it it any auto parts store and have it checked. I think you could have a either bad connections or bad starter
500dollar744ti
Has your starter been wet recently? Sounds like you simply have an internal short in the starter. I would be looking to replace or rebuild.
