Crankshaft end play 1.5hp Johnson
RPJS
Modle # SC10S<br /><br />I have just dialed the crankshaft end play on this motor at 0.83mm (0.032"), the manual I have does not list this measurement, but this seems excesive.<br />Can anyone tell me the correct figure for this motor and if needed how I should correct the movement. Do I shim the crank or replace the bottom crankshaft bearing housing gasket for a thinner one.
RPJS
Re: Crankshaft end play 1.5hp Johnson
RPJS
I could realy do with some help on this.
