crankshaft socket
bfjou812
Does anyone know where or if a crankshaft socket is available for a Mercruiser 470? This is to turn the crankshaft without the damper on the crankshaft. Thanks
Bt Doctur
Re: crankshaft socket
DO NOT try using the crank bolt, it will break.
why not temp reinstall it.
Or remove the drive and have a old input shaft welded to a section of pipe to make a "T" handel tool
