Cranky
stuco
Have a 2007 stingray19.5’/ only 180 hours- good battery- not getting it to crank/ even tried jumping off my truck directly to starter and nothing- any ideas?
San_Diego_SeaRay
I just had an issue w. my starter. I thought it was going bad, it would try to turn over then you'd just hear a loud "Click...click..click...". I was going to swap it out for a backup starter I had. When I pulled the starter off the engine, I decided to re-check it. Worked fine when removed and with jumper cables hooked up to it to a battery. Turns out that the face where the bolts mate with the engine block was rusty. Water was dripping down the engine block (either rain water or manifold.. I'm still investigating..) The water seeped right into that gap and caused it to rust. Apparently this is what the starter was using to ground itself.
Long story short: Make sure the starter has a good ground. I'd use one side of a jumper cable to ground it when trying.
stuco
Thanks for the tip- I did some of what you said by attaching positive directly to starter - but didn't attach negative to same area- I'm on it !
are you hearing a soft click, or a hard Thwack
a soft click is dirty contacts or a failing pilot relay
a hard Thwack is a hydro-locked motor or something else preventing the motor from turning.
