Crappy base gaskets?
rothfm
Ensign
Just bout several Sierra powerhead base gaskets
The are so thin and flimsy im not sure i want to use them. Made of non coated paper material.
At least the envelope said sierra anyway, maybe the seller put something else inside
Is there a good thick gasket? BRP brand maybe better? I typically have exhaust leakage problems and want to avoid it this go around
Thanks
Any issue doubling them up
I know the factory gaskets for V-4 / V-6 are / were wire mesh sandwich.-----Well worth the extra pennies !
daselbee
Sierra base gaskets are .015" thick, while OMC OE base gaskets are .045" thick.
This measurement being taken on the V6 90's looper base gaskets.....
rothfm
Ensign
Thanks guys...Yea for some reason I thought I had one awhile back that was pretty thick and sturdy material.
Will Nix the cheapo ones, and get some originals. Hate putting a motor together and then having the streaks down the leg.
clanton
Service bulletin changed part number and gasket material for some cross flow V6s. I no longer have bulletins or manuals or I would look for the PN for you.
rothfm
Ensign
Seems the superceed is pn 0342513 More pricey, maybe this is the thicher better one. Will be ordering soon, Will update post
Thanks
daselbee
Clanton's baaaackkkk. Hey young man. You want to go to the Florida Flywheeler's Swap meet on the 18th thru the 21st?
betayv
I jus replaced the base gasket on my 1987 150, i paid 20$ original evinrude mesh gasket, big difference with that cheap paper gasket.
