Crazy Tachometer
swede4198
I have a 2008 Sedona FS21 pontoon boat with a tach that at times seems to be operating correctly, other times it seems to be doubling the RPMS. I know my 1999 Merc 90hp 2-cycle does not accelerate to 7,000 RPMs just off idle nor will it cruise at 6,000 rpms at while doing 14mph. Any ideas how to fix this tach?
first verify the tach. I use a hand-held laser tach
Silvertip
Locate the calibration dial on the back of the tach and note the current setting. With a small flat blade screwdriver rotate the dial back and forth (GENTLY) to burnish the contacts inside. The set the tach at its original setting and give it a try.
