ibrw1
- Nov 13, 2010
- 252
Mercruser 1999 5.0L 2bbl Thunderbolt-5 engine serial #L345059 Crownline 202 BR
2 problems
Hi, I have a strong gas smell when I remove the boat cover. Issue just started. I've checked the gas lines from the tank to the electric fuel pump and all the way up to the carburetor. My gas tank is in its own compartment in the boat. I ran a 3/8" poly flow tube through the wall and down into the bottom of the fuel tank compartment. Applied a vacuum, had everyone sniff the of the air being pumped out. Imagine a pump used to inflate/deflate air mattress with a tube connected to it. Anyway, No gas smell at all. I don't see gas in bilge either.
I watched pressurized gas lines when underway. No drips, no wet spots no loose clamps, No smell of gas.
Parked boat, put cover, next day, removed cover, gas smell is back.
a) it's gas smell
b) it's strong
Problem 2, tied to problem 1????
Only after 30 plus minutes with 10+ people in boat, cruising along at 40 plus mph, engine stalls for 1/2 second. As if someone shut key off and right back on. Every 10 to 20 seconds, same thing. I slow to an idle for 10 minutes or so, problem disappears. I speed back up, after 20 plus minutes, issue returns.
Note, both issues started same day. I have 40 gallon gas tank. Had 16 gallons remaining when issue started. I have a fuel minder.
Ideas?
2 problems
a) it's gas smell
b) it's strong
Ideas?
