cruise-a-day tank installation
wayne-mayle
i have a 1952 Evinrude 7.5 hp mod #4447 and would like to know if i can convert to cruise-a-day tank. if so what would it take, thanks for any help
tomhath
Master Chief Petty Officer
There are a couple of ways to do it. Try searching Leroy's Ramblings or YouTube for detailed instructions..
F_R
You would have to install a fuel pump and rig up a pulse line to drive it. Easiest way would be to tap into one of the bypass covers on the side of the powerhead. Make sure you have enough room first.
gm280
F_R is correct above. A pulse fuel pump like what's on most older Johnson and Evinrudes would be the best type set up. And If I am not mistaken, some of those pumps have a tube that supplies the pulse from the engine and not just bolted up to an opening port. And since those pumps are small in size, you maybe could even manufacture a bracket to fit it to the engine under the cowling. Do a search for such pumps and see. JMHO
F_R
No Title
This should give you the general idea what you are striving for. This is a Briggs & Stratton pump on a Gale motor. Yeah, I'm aware that on this motor a regular OMC pump would have bolted up directly.
