Mercruiser 5.0 Alpha 1999 8 cyls.<br /><br />I took the boat out first time this season last weekend. Cruised for 15 minutes, I stopped to anchor, then motor died. Restarted, then quickly died - happened about 3 times. Motor started strong when in full wot but motor died within seconds. Attempt to restart more than 8 times was not successful. Engine cranked but did not start. Had to be towed.<br /><br />At home, I replaced the fuel/water separator, did not observe any water (transferred fuel to a clean bottle and watched for water), changed plugs, changed plug wires. Two plugs smelled gas, and all 8 are black ( from oil fogging?) Recharged battery. Tried to start, got strong cranking, motor started on 4th attempt, then died after 20 seconds. Tried restarting 4 - 5 times, good/strong cranking, but did not start again. Electric fuel pump is working.<br /><br />Tomorrow,I will check the fuel filter on the carburetor inlet and check for blockage.<br /><br />Can someone give me a few other leads? <br /><br />Thanks.
