Crusader engine performance
Gary Scott
Looking to buy a 1987 Trojan 32 flybridge cruiser with Crusader 270 HP engines. Taking a test ride first before hiring a mechanic to test engines. What kind of Max RPM should I expect to see, engine temps, and oil pressure. Engines are raw water cooled. Thanks.
Re: Crusader engine performance
I'd be looking for;<br />WOT rpms.....44/4800<br />temps.....145* to 180*<br />oil pres.... over 15psi at idle, less than 70psi at WOT<br /><br />Compression,+ vacuum tests will tell you alot...
geriksen
4400,4800 would be great<br />4200,4400 o.k and likely
magster65
Raw water cooling? On a 32' Trojan? Are you sure?
