Re: Cuddy Carpet Removal
G'day Dave, Janette here rigby's missus. Just happens we are both carpet layers, removers and general trouble shooters regarding carpets here in Australia. Big problem if your carpet has been stuck with contact. If you pull too hard depending on what your boat is made of it may pull whatever it is attached too off before the contact will give way. If this is the case we find with carpet that cutting it into really small strips and pulling bit by bit. An alternative to this is as ThomWV suggested is using a solvent product which will help, Just watch the fumes, it will make most glues moist enough to remove, hubby just suggested to test a small patch to make sure it doesn't react to your boat first. Afraid contact is about the best thing to adhere carpet into boats with because it can withstand the salt water. Mate your in a catch 22 position here. Hope this helps. Janette.
